Attex help
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: Attex help
  1. #11
    Adam in Va is offline Registered Rider Adam in Va is on a distinguished road
    Join Date
    Nov 2014
    Posts
    29
    Frame is in good condition, just the motor mounts are bad. What would be down side other than vibration to solid mounting the engine? That should fix my belt issue.
  2. #12
    Join Date
    Nov 2014
    Posts
    29
    I'm also thinking about swapping in a Honda 9hp 4 stroke. New 40 series clutch on engine too. Would than be enough to putt around?
  3. #13
    racerone3's Avatar
    racerone3 is offline Driver X racerone3 is on a distinguished road
    Join Date
    Oct 2007
    Location
    statesville, north carolina
    Posts
    2,354
    to putt around it would be fine. Attex 208TT was basically the same machine as yours with an 8hp briggs flathead. some Scramblers of the era also used the 8hp briggs
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
