Engines pulled apart ready for short rebuild, contemplating new rings???? Yes/No???? It had like 110psi on each cylinder.
But i like things clean so there's that lol.
Few more
Well the T-20 is apart. I have never rebuilt one, although I have rebuilt Cub Cadet & JD Hydrulic Transmissions before I know big difference lol.
I know i need a new left Diamond shift plate the pin is worn flat on one side, the right one looks fine.
As for the drums and bands I really have no frigin idea...
Help please....
And five more.
It's hard to tell how much is left on the bands but if it were me I would send them out and get them re-lined. That way there is no question and when you put it back together and reinstall you won't have to worry for a very long time. The shifter can be fixed by replacing the pin. You have to heat the it and pull the pin then press a new one in or you might find one from one of the guys on here.
Aww thats nice to know, i wasn't sure if i had to buy a whole new shifter.
Also mine has the compression rings that hold it in, can i not put thise back in and just get 2 brackets instead??
Ditch the snap rings. I just build my own hold down brackets from sheet metal
Kwl, i can do that.
Ol next dumb ? What one would you recomend?
This is best. 4741B SHIFT PIN - T20
