looking for advice on body repair
+ Reply to Thread
Results 1 to 6 of 6
Thread: looking for advice on body repair
  1. #1
    gearbound is offline Registered Rider gearbound is on a distinguished road
    Join Date
    Dec 2017
    Posts
    23
    Its a 1970 body that has some cracks in the body and shattered corner at the back. looking to use fiberglass from the inside. in addition id like to reinforce the front and bottom since it is old plastic.
    advice on best method is greatly appreciated!
  2. #2
    Mike's Avatar
    Mike is offline Administrator Mike will become famous soon enough
    Join Date
    May 2007
    Location
    Kings Mountain, NC
    Posts
    7,765
    You probably will want to avoid using fiberglass just because it won't hold up in the long run. Your body sounds like it is ABS but it could also be HDPE. If it is ABS, you can repair it by mixing acetone with pieces of ABS or by air welding it. If it is HDPE, you can also air weld it with a cheap welder from harbor freight. Search the forum for ABS repair and there are several threads that should help you out. Here is one to get you started: Attex 295 question
  3. #3
    Join Date
    Dec 2017
    Posts
    23
    mike,
    thank you. im looking at buying ABS pellets and the fiber mat with acetone to repair the body. also looking for HDPE in 1/4 black to make a skid plate. i assume rivets are all that is needed.
  4. #4
    Craig_B's Avatar
    Craig_B is offline Sophomore Slider Craig_B is on a distinguished road
    Join Date
    Dec 2015
    Location
    Barrie, Ontario. Canada
    Posts
    88
    I wont know until spring how effective my repairs will be but I made a patch and filled some cracks using HDPE and windshield adhesive. That stuff sticks to Anything.
    Also used a product from JB Weld
  5. #5
    Join Date
    Dec 2017
    Posts
    23
    i bought some abs pellets off ebay and fiberglass mat. this will be my first attempt at closing up holes and sealing up cracks
  6. #6
    thebuggyman1's Avatar
    thebuggyman1 is offline Scaring frogs everywhere thebuggyman1 will become famous soon enough
    Join Date
    Nov 2009
    Location
    Charlotte, Mi/ Houghton Lake Mi
    Posts
    2,870
    This stuff is made for plastics and WILL hold up, I have proof. lol
    https://www.youtube.com/watch?v=2a5RlcP-4JE
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
