Attex top abs piece
+ Reply to Thread
Results 1 to 8 of 8
Thread: Attex top abs piece
  1. #1
    Join Date
    Feb 2018
    Location
    Ohio
    Posts
    82
    Attex top abs piece
    Does anyone sell the top piece of the attex?
    Does anyone sell like a skid plate for these?
    Does anyone know where I can source brake pucks, mine are solid and do not have a backing and it takes 8!
    Thank
    Don
  2. #2
    Join Date
    Dec 2007
    Location
    amesbury.ma.
    Posts
    227
    HI bentvalve, Someone on the site will possibly have a top. I made a skid plate for mine out of 1/4 inch abs. Melted abs pellets in acetone till it turned to putty and glued it between the chain troughs. You can use the abs putty to fix cracks if you v them out and soften the crack with acetone. Brake material can be bought from Mcmaster-Carr and bonded on with jb weld or high strength epoxy. Good luck mike
  3. #3
    Join Date
    Feb 2018
    Location
    Ohio
    Posts
    82
    My pucks have no backing. I know they are 1 1/4 so I know what thickness to purchase!
    Thanks for ur help!!
  4. #4
    Join Date
    Dec 2007
    Location
    amesbury.ma.
    Posts
    227
    Hi again, Find a hole saw thats 1 1/4 inside diameter. Remove the center drill and use a drill press if you can. Cheaper than paying Richards Relics prices. Good luck. Mike
  5. #5
    Join Date
    Feb 2018
    Location
    Ohio
    Posts
    82
    I have the source to get material just need to know how thick they are supposed to be.
    Yea, I thought $64 was a touch high if I can buy a big sheet and make them myself.
  6. #6
    aprox 5/16 thick by 1 1/4ish in diameter
  7. #7
    Join Date
    Sep 2013
    Location
    Caldwell, Idaho
    Posts
    1,174
    Quote Originally Posted by Bentvalve View Post
    http://www.6x6world.com/forums/attex...970-attex.html
    ST400R ATTEX(Smiley)
    500 Super Chief
  8. #8
    Join Date
    Feb 2018
    Location
    Ohio
    Posts
    82
    Thank u sir!!!
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
