Engine swap
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: Engine swap
  1. #11
    Join Date
    Feb 2018
    Location
    Ohio
    Posts
    82
    I have no idea what that mess is...what is it supposed to look like? That picture is at the guys house I’m getting it from. Think the converter is bad?
  2. #12
    Join Date
    Nov 2009
    Location
    Charlotte, Mi/ Houghton Lake Mi
    Posts
    2,910
    Quote Originally Posted by rickga View Post
    looks like a 7000. From what i understand the 5000 doesn't have reverse and that looks just like my 7000. looks like you have some spring issues though
    The 5000 and 7000 look alike. The 6000 is without reverse. I'm not sure what all parts interchange, just that the 5000 is a lighter duty model with a smaller dia. shaft.
  3. #13
    Join Date
    Feb 2018
    Location
    Ohio
    Posts
    82
    Not sure if that’s something wrapped around it. I asked the guy who has it to look at it.
    If the thing is broke is that a hard piece to replace?
  4. #14
    Join Date
    Jul 2011
    Location
    Clarkesville, GA
    Posts
    469
    Quote Originally Posted by thebuggyman1 View Post
    Thank you buggyman. I did not know that
  5. #15
    Join Date
    Feb 2018
    Location
    Ohio
    Posts
    82
    Yes, thanks!
    Well I asked, the guy said it looks like someone put that mess on that converter to make it enguage better? Lol
    I’m probably gonna be looking for a back up unit.
    Don
  6. #16
    Join Date
    Feb 2018
    Location
    Ohio
    Posts
    82
    So, do the sled engines turn the correct way?
    Like I said I got 2 engines with it, just kinda need
    To understand how the primary clutch will work with the
    7000 tranny.
    Thanks
    Don
  7. #17
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    Quote Originally Posted by Bentvalve View Post
    7000 tranny.
    Thanks
    Don
    The engines should work no problem, the convertor will probably need to be wider inside using spacers, we hope. Rickga is currently working through this with a small 4 stroke conversion, the belt width is the main issue.
  8. #18
    Join Date
    Feb 2018
    Location
    Ohio
    Posts
    82
    I have a belt, not sure if it came with sled engine or not.
    It fits the engine but kinda fits in the driven clutch. Kinda trying to eliminate the issue before I have an
    Issue I guess.
    Thanks
    Don
  9. #19
    Join Date
    Feb 2018
    Location
    Ohio
    Posts
    82
    I guess after getting it home and looking at it someone stuck rubber hose in the spring
    Not sure why? Maybe so it would engage sooner?
    Don
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
