I've had my springer 7 and a half years now and since it's original build, the body has bothered me. The Superchief platform I used must have had a carb backfire/fire at some point because the back of the tub is charred and melted in spots
Two years ago I got my hands on some virgin Attex tops (thanks member Tony).
Attachment 13684
I finally managed to secure a poly bottom for the Apache. The bottom came in a lot that ArgoJim and I picked up last December. We found a pretty sweet deal on four machines in Northern New Jersey. All I needed from the lot was the one machine (a Chief that had been transplanted into a poly bottom at some time during its life). It also came with a factory roll bar. I'm still not sure what I'm going to do with the roll bar. I also got a T-20 that appears to be ok but I still need to open it up to be sure.
Attachment 13682Attachment 13683
It has no holes in it but was clearly filled with water almost to the belly band at one time.
Attachment 13679
Removing the rust took a little while to figure out. Power-washing did not work, neither did CLR. JerseyBigfoot suggested muriatic acid and I also got the same advice on a boating website. The acid is available at pool supply stores.
I plan on getting the new tub ready during the summer and making the switch in late fall.
Attachment 13680
