Bearing and axle upgrade question on early st300d
Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Bearing and axle upgrade question on early st300d
    Oct 2012
    Fort Mill, SC
    69
    I used Alro steel near the airport in Charlotte then cut them myself.
    Jan 2008
    Vicksburg, Michigan
    3,507
    Unless you are doing a different bearing set up the axle is 25mm stepped up to 25.4 on the inside. 25 mm pressed fit outer bearing.
