Well I have been working on fixing my cracks and just thought I would post why these cracks are here. Well actually they where there when I got them. But I did make them worse. These cracks are the result of climbing logs that are able to fit between the tires. The worse one is fixed and I wish I would of tooken a picture of it but did take one of the other side today before I fixed it. I will post the fixed picture of it when I am done. Seems how this is abs it is a piece of cake to repair. Just soften the body up alittle with the acetone and spread the abs/acetone(50/50) mixure on. Let it dry. I plan on doing something to reinforce this. Kinda thinking maybe 1 1/2" angle iron on both side down bottom held on by some metal attached through the axle bearings. Maybe something in front and back across from 1 side to other to work as a skid plate from impacts. But that is all in the planing and might not do it.
I also repaired a hole I got when the chain popped and wrapped up on the center sprocket. It is on the bottom so Im not going to sand it but if it was visible it can be sanded down and if color matches will look like new. This was actually a hole,not just a crack. Like maybe 5mm x 10mm so it was small. But after like 5min it was done including prep. Then let it sit over night and good as new. Easy to fix but being abs is easy to break as well.
