Hey yall,
Got a question for yall in regards to ABS repair.
I am starting on getting this abs body back to its former glory.
So far and have gotten great results with wet sanding with 120/150 grit paper on a foam block. I have also tried acetone. Acetone works well but it gums up the cloth(using white cotton undershirts) I think acetone will work better when the body is closer to complete.
My plan.
1. sand body with 120/150 grit wet(w/ water) to remove faded color and remove 95% of the black marking from the body.
2. make body repairs to cracks using abs goo.
3. sand with a 300-400 grit paper to get a clean smooth surface wet (w/water) and remove the remaining 5% of black marking.
4. use acetone to clean up any imperfections and have a better than new bright yellow abs body.
So here is some of the results I have gotten so far.
^This is what it looks like when I come back the next day...
Any input on how to stop this from happening? Do I need to wax or seal this when I am done and if so with what?
Thanks
