Apache Springer Facelift
Page 4 of 6 FirstFirst ... 2 3 4 5 6 LastLast
Results 31 to 40 of 53
Thread: Apache Springer Facelift
  1. #31
    Phoenix,Az.
    1,629
  2. #32
    I want to trim off the extra HDPE on the upper. I put the frame/cage in temporarily to help prevent any warping that might occur when marrying the two halves. Once everything looks good, I'll mark off a cut line and take everything apart to make the cuts.
    I also removed the old staples from the Apache's original belly band to use with the rebuild.
    I trimmed the top and attached it to the bottom last week. I also started re-attaching the side-plates and got two of the inner axles back in.
    Today I finished getting the axles in. I also fought with the belly-band. I put the tranny back in but not before changing the ATF. It takes less than 5 minutes to do that when the T-20 is outside the car.
    Tomorrow I plan on changing the engine oil and re-installing it, getting the outer axles and arms back on and finishing up the wiring.
    Phoenix,Az.
    1,629
  5. #35
    Sep 2013
    Caldwell, Idaho
    1,174
    Nice work
    So clean
    ST400R ATTEX(Smiley)
    500 Super Chief
  6. #36
  7. #37
    Sep 2008
    woodland pa
    534
    Thumbs up Larry W
    nice work George you will be happy when its done
  8. #38
    GTG next week?
  9. #39
    Thanks everyone!
    It's going to be very close Jim. Probably.
    If I had another 45 minutes of daylight I would've had half the tires on Whip!
    Nov 2009
    TUCSON
    777
    that looks fast, i thought i would see a supercharged big block but that will do
