Levers work backwards
Results 1 to 4 of 4
Thread: Levers work backwards
    I am finishing a rebuild on a early gen attex. It has a baker hill 7000 trans, a harbor freight 13 hp. Engine. The problem I am having is that the steering/brake levers work backward. Pull to go push to stop. Linkage is hooked correctly per manual. Any ideas
    Jan 2014
    clifton IL
    813
    Motor turning trans pulley correct direction??? Just a wild guess here! Never seen a baker hill before!!
    What did you find?
    Butler, PA
    191
    If the machine is in reverse the stick movement would be correct. If it is in forward gear I would say that the left and right caliper levers may of got reversed?
