Attex 26 tooth vs 20 tooth???
Results 1 to 5 of 5
Thread: Attex 26 tooth vs 20 tooth???
    Jan 2014
    clifton IL
    813
    Ok fellow 6x6ers. What sprockets are better for power and torque?? The 26 or the 20s. The machine I'm workin on has 26 tooth with a 22hp predator and just curious to see if y'all know which is better. Also using new lower tub from mudd ox and it appears the 26s make chains go pretty far below the frame.
    Thanks for any input on this
    Dave
    26's are power, 22's 20's are speed.
    Meadville, Pa
    3,286
    Most superchiefs came with the 26 tooth sprockets due to then having the big 2-stroke in them. The engine provides the speed and the sprocket gives them the torque. The Tomahaks seemed to come with the 22 tooth sprockets as the engine provides the torque, the smaller sprocket gives it the speed. When I upgraded my tomahawk, I believe I put 24's on it. The stock 22's made it fast, but I had a desire for a bit more low end grunt. Essentially, I felt the 24 were a good compromise for a well rounded 4-stroke Attex. It is still quick, but can pull a bit better than it used too.
    Jan 2014
    clifton IL
    813
    Ok thanks ARGOJIM I was thinking that but wasn't for sure!
    Jan 2014
    clifton IL
    813
    Thanks Drew. I'm goin with the 26s on this machine and I was wondering if there's any standard measurement to mounting frames in the new lower bodies?? I'm a lil nervous about cutting these holes out!!!
