Attex 295 Wild Wolf no spark
Results 31 to 34 of 34
Thread: Attex 295 Wild Wolf no spark
  1. #31
    Jan 2014
    clifton IL
    813
    Quote Originally Posted by 507rzr View Post
    Adjusted float and now fuel runs out exhaust. Guess carb needs to come off again to lean it out. I really didn't think I moved it that much though. Must be a very finicky engine.
    you may have filled the crankcase full of fuel so be careful turning motor over with spark plug out.caught one of mine on fire once when the plug wire fell on the head as i eas pulling starter rope!!
  2. #32
    Jun 2017
    Robinson, IL
    72
    Seems like the fuel is collecting in the crankcase and not making it to the top of the Piston. Any explanations?
  3. #33
    Oct 2017
    New jersey
    4
    Never worked on that motor but does it have reeds in it? You might want to pull the pulse line and crank the motor and check for pulse, i have seen pulse lines fill with fuel or oil for that matter and not pull fuel. And if u put your hand over the carb inlet and crank u should feel u pull on your hand.
  4. #34
    Jun 2017
    Robinson, IL
    72
    No Reeds. I am getting fuel in the pulse line. Seems to be coming from engine side though. I don't find any leaks in the pump.
