thanks Jeff and Don, i love this site! learn something everyday
OK guys, thanks for all the help and encouragement so far!
I have decided that this is more fun than ever, and I am starting to do a teardown/rebuild of this attex.
I was tearing around yesterday and lost a axle bearing. Rather than do a repair, I have decided to do a more complete job. I am planning to pull the frame out and paint it, do some body pan repairs, replace axle bearings, seals and chains. So I will be busy for the next few months.
I had an awesome time riding around for testing, but now is time to do some permanent repairs.
Thanks again for your interest and help. You will be hearing from me.
Lamar
OK
I got some Acetone today. Acetone definitely softens the material, so I guess that makes it ABS?
Thanks
Lamar
Yup, it's ABS. Has all the makings of a really nice machine. Good luck with it!
Hi again,
Thanks for the interest, guys.
I now have the ole girl tore apart. I posted pics in my gallery if interested.
The axles were tough to get out of the bearings and sprocket tubes, but since 3 of them were bent, and I plan to replace them anyway, I just cut them off with a sawzall and then pressed the sprocket tubes off. I plan to make new axles to fit some more standard ATV wheels and tires.
New bearings, axles, chains, wheels, tires, etc will be forthcoming as budget permits.
I plan to paint the frame, repair the body pan and install a hitch while it is apart.
I received lots of help and tips from members here and from the technical parts of this site.
Thanks to all.
Lamar
Hi guys.
I am finally taking time to report some progress here. I got lots of help earlier and I appreciate it.
The axles, bearings, chain, wheels, tires are all installed. 6 new Carlisle Strykers are mounted and ready to spin! T20 Trans is gone over and installed. I used 3 wheeler hubs welded to new 1" axles and all new bearings.
Next is engine. I have a B&S twin 20hp setting here ready for install, but have some question on the clutch. The original JLO has a tapered shaft for the drive clutch, the B&S has 1" with key. I have some question about 4 stroke rpms compared to the JLO 2 stroke. Will the clutch work or is RPMs too low on the 4stroke? I can get an adapter sleeve made to put the clutch on if I am assured that it would work.
Thanks
I will try to post some pics later.
Coldnorth
