Axle removal on Superchief
Results 1 to 4 of 4
Thread: Axle removal on Superchief
    Hi Guys new to the world of six wheelers, But I recently bought an Attex Superchief. I have a bent rear axle I'm trying to remove but having trouble getting it out. I can get it to spin inside the sprocket shaft, but it won't pull out. Am I missing something? The guy I bought it from claimed that all I had to do was pull out the bolt that goes through the axle. Any help would be appreciated! Thanks Brian
    Jul 2009
    Sandusky oh
    184
    On my st300d I had to pull the outer bearing.
    Cave Trolls Rule!
    Aug 2007
    near olean, ny
    1,083
    Smile attex axles
    Quote Originally Posted by bahooy View Post
    you are VERY lucky the sprocket moves.. there are 4 bolts on the bearing flange, 2 or 4 set screws on the bearings(2 on each)... then. take an old 1/2" or larger bolt, and a lfh, instead of a B.F.H, knock the axle out from the inside
    Thanks for the quik response I'll try it tomorrow.
