attex plow mount
Results 1 to 4 of 4
Thread: attex plow mount
    Sep 2008
    woodland pa
    534
    attex plow mount
    was considering putting a plow on the attex found a 42 " plow no mount/ how do you make a mount??????? and best placement for winch???? will it effect ground clearance. Any pics of one would help
    Sep 2008
    woodland pa
    534
    attex plow mount
    this is what was on my attex front corners. Should i make something like this to mount my plow but fill in where my fingers are and weld on some solid bar for plow to pivot. Should i make the mount to go the whole way across the front for a lower tub protector i have no skid plate something like the springers have i know it saved georges machine when he hit the pallets last year at the philipsburg rodeo. Last do i angle the plow and how much and is a 42" plow big enough or should i extend it
    Jan 2008
    Vicksburg, Michigan
    3,507
    http://www.6x6world.com/images/broch...w-brochure.jpg
    I know there was a pulley on the nose for the winch cable but Im not sure where the winch was mounted. Im also not sure on the plow mounts. Usually there attached to the front on the bearings.
    This post has the pulleys.
    http://www.6x6world.com/forums/attex...do-i-have.html
    other post
    http://www.6x6world.com/forums/attex...low-attex.html
    I like pillow block bearing idea on the front and middle axles.
    Pittsburgh, PA
    695
    My dad's attex has the cable running to a foot pedal inside (no winch) mounted to the frame. The pulley set up looks identical on the front.
