I should have mentioned I have the 27 hp Kawasaki. The solenoid is on the starter itself. The solenoid clicks but doesn’t engage to the flywheel. I will triple check the wiring. Such an intermittent...
Since you provided a list of items you have done, I believe you have either a bad starter solenoid or there is still an issue with the wiring such as a loose connection or an internal break in a...
What engine do you have? When you say it clicks but wont engage, where is the click coming from? Is the solenoid clicking and the starter motor not spinning? Or is the starter not engaging the ring...
Try checking the amp draw the next time it happens. If it is real high at the starter try turning the engine over by hand, then try the key again. If you have little to no amp draw you know the...
The BMB Bottmobile Boondocker is a five wheeled amphibious ATV that included a mower deck as an accessory. This brochure has several cool pictures including one that markets the boondocker as a golf cart
I should have mentioned I have the 27 hp...
tbone9 03-27-2024, 01:56 PM
