6x6 World - Max II Engine Replacement--Engine Installation
  • Max II Engine Replacement
    Place the motor back in the Max and slide the belt back on. Then position the motor over the mounts and insert the four bolts and washers. Leave them loose for now so that you can adjust the position of the motor.
    Position the motor so that the belt runs straight and true. Then slide the motor towards the back of the Max to get the belt tight.
    Place the exhaust gaskets between the exhaust and the engine and bolt the exhaust back into place.
    Tighten the motor mount bolts while keeping tension on the belt. Then slide the stop on the left side of the frame towards the rear until it touches the motor mount. (See the photo below) This helps to keep the belt from pulling that side of the motor forward over time.
    If you missed it earlier, reconnect the ground strap to the motor.
    Reconnect the fuel line, starter solenoid wire, and wiring harness plug. Then reconnect the throttle and choke cables.
    Happy 6x6ing!
    This article was originally published in forum thread: Max II Engine Replacement started by Mike View original post
  • 6x6 ATVs on eBay
  • 6x6 World Sponsors
  • Latest Poll
    Do you want to see a new 6x6world website? (9 Votes)
    1. Yes, I'd like to archive the current site and start fresh with modern forum software. (6 Votes)
    2. No, I would like to stay on the original website as long as possible. (3 Votes)
