T20 Skid Steer Rebuild
Remove the c-ring on the T20 input shaft. Jeff has a great picture of a tool that makes it easy to remove these in his
T20 article. I just used two screwdrivers, one on each ear of the clip and hit them at the same time. Just be careful because this clip usually comes flying off.
Remove the sun gear.
Remove the washer with the ear on it.
Remove the center housing plate.
Again remove the band anchor rod and sleeve from the brake bands just like before. Then remove the carrier drum, sun gears, and needle bearings as one unit.
Remove the washer with an ear.
Remove the three thrust washers.
Again make sure to reassemble everything upside down so that you don’t lose any parts.
Thank you, North Country! I will do that. ...
Rowdy 04-25-2024, 09:54 AMAfter I put the 2 new 21x11x8 22 Mag tires I had on, they?re actually shorter than the original tires by an inch or more. I don?t think I will have any...
