T20 Skid Steer Rebuild
Let’s start by reassembling the clevis and bands. If you will notice there are two different bands. One has the plunger on top and the anchor point on the bottom while the other is the reverse. You want the plungers to be closest to one another in the center of the transmission so the first band should have the anchor point at the bottom.
Put the band and plunger with no o-rings into the T-20 transmission case. Apply a liberal amount of vasoline on the plunger and slide it through the housing from the inside all the way through to the outside. You may have to install the plunger bolt and pull it through from the outside to get it there.
Then you want to coat the new o-rings liberally in vasoline and slide them on the plunger into the appropriate grooves.
TIP: Next we will be pushing the plunger back into the housing. Before doing so I recommend putting the bolt and rectangular washer from the brake lever back onto the plunger. Without it, it is easy to accidentally push the plunger back into the inside of the housing. If you do this later in the assembly by mistake and try to push it back in from the inside of the housing you will most likely tear the o-rings and they will not provide a good seal.
Repeat the process and install the upper band. That band should have the plunger towards the bottom (or outside) of the housing and the anchor point near the top (or center) of the housing.
Install the new bearing.
Install the bearing lock ring by walking it around the groove.
Install the oil seal. Make sure that you gently tap the seal in place in an even manner or you could risk damaging the seal.
Optional step – The reason that I had to rebuild my transmission was because a main seal worked it’s way out of the transmission housing. In order to hopefully prevent this in the future, I took a punch and pinged the housing in several places to help hold it in place. This day I only had a small punch. If you will read on to the other side’s reassembly I have the correct sized punch and only hit the housing in four places with it.
Now you can install the output shaft from the outside of the T20 skid steer housing.
You may have to gently tap it until it goes in place.
Thank you, North Country! I will do that. ...
Rowdy 04-25-2024, 09:54 AMAfter I put the 2 new 21x11x8 22 Mag tires I had on, they?re actually shorter than the original tires by an inch or more. I don?t think I will have any...
