Just swapped a 16 horse vanguard onto my max. As I was cleaning the carburetor, I noticed a small black knob on protruding from the side of the carb ( same side as the pull rope). It turns about 90 degrees. What is it?
Printable View
Idle air fuel adjustment cap. It's set at factory and capped with the limit only adjustable a small amount. Most run best at the stop turned counterclockwise.
Just cleaned my carb on 16hp Briggs. Played with the throttle adjustment for a while to get it to idle low enough so it wouldn't grind when switching gears. Finally decided to try that black adjustment knob and after a few settings found that full counter clockwise my machine runs like a top. Can get it to idle super low rpm now.
