new to 6x6 world just bought a well used 2006 8x8 argo frontier engine bogs when turning I think its done thought about 22 predator don't know if shaft size is compatible with cluch
Printable View
I'm currently installing one in a Vanguard II. Stock clutch lines up with the Predator shaft just fine. Did anyone use the Briggs exhaust for the Predator?
We run mostly these predator engines. You will have to build a custom exhaust for them. Pretty easy you can buy the flanges and go kart pipe separate or there is a kit.
Exhaust, Flange, Header, GX270 to GX390
Exhaust, Flange, Header w/stub, GX270 to GX390
Honda GX670 GX690 V-Twin Header Kit
Honda GX670 Predator 670cc V-Twin header collector kit
My next build will be a 2 into 1 and see how it sounds.
can you use a clutch from a jlo 295 on a 22 hp predator?
No you need a straight shaft 4 stroke clutch.
anyone have one for sale that will work?
looking to set the governor to 4900-5000 rpm on the 22hp predator. on the single cylinder motors the go kart fellas just shorten the spring. would that work on the v twin?
I have the rev kit from 670 Performance. It increases the rev limit to 4600+/-. I could tweak the sprng to 5k but not with the stock flywheel and internals.
I bypassed the governor with no issue. Revs till the valves float.
