Dan67's Hustler 950 Rebuild
Page 14 of 14 FirstFirst ... 4 12 13 14
Results 131 to 137 of 137
Thread: Dan67's Hustler 950 Rebuild
  1. #131
    Feb 2008
    Kentucky
    108
    That is awesome Dan. I would love to use that jig when I'm ready for it if you wouldn't mind.
  2. #132
    Jul 2011
    Garner, NC
    865
    Quote Originally Posted by Dan67 View Post
    Started upgrading to new splined axles from whipper. For now I am doing the center axles that drive the machine. I broke way too many shoulder bolts at busco and it was a down right buzz kill. At the same time I am upgrading to new Argo HDI bearings and flanges on the outer bearings. Whipper was kind enough to machine a drill guide that is just perfect. Got bearings from Buffalo Bearings and HDI parts from Tim at Adair. Local Fastenal now carries zinc coated grade 8 bolts, washers, & nuts. Been busy morning sofar, center axles removed without much problems. Now onto pulling the motor so I can get the broken left rear out and swapped with an older center axle.
    Great idea you have there Dan, going with the HDI Bearings!! It really looks stout!! You will be absolutely amazed at how more aggressive you can drive now, knowing that you will not shear any more pins,,,, well at least not on the centers for now!!!!! Looks good Dan, courtesy of Whipper!!!
    BIGFOOT ALUMNI
  3. #133
    Mar 2010
    Oconee County, SC
    823
    Started working on phase II of my upgrades. Got 4 new axles and sprockets from whipper. Will replace remaining bearings to Argo HDI standard. Also replacing inner bearing flanges to cast flanges. Bolts right up to existing holes. Inner are SBLF205-16. Buffalo bearing is the place.
  4. #134
    2,635
    hey dan, take some pictures of yourself also during the build so we can see the smiles get bigger !! john boy va.
  5. #135
    Mar 2010
    Oconee County, SC
    823
    Got a bit more done today. Fronts are now HDI. Removed the center HDI and bearings. Replaced bearings. Cleaned axles and painted them. Slowly getting it done.
  6. #136
    Mar 2010
    Oconee County, SC
    823
    Just a bit of an update. Installed 6 axles and sprockets. Used new cast flanged inner bearings. Just waiting on new chains.
  7. #137
    Mar 2008
    Rockwell, N.C.
    2,627
    Looks great Dan! Keep pushing.
Tags for this Thread
