Predator 22 hp
Page 8 of 9 FirstFirst ... 6 7 8 9 LastLast
Results 71 to 80 of 82
Thread: Predator 22 hp
  1. #71
    Nov 2009
    Michigan
    730
    Not sure. If I had to guess high 4's low 5's. Its screaming. Biggest benefit of removing it is the power when you squeeze the throttle. Dont float the valves that often. Only on long straights screwing around.
  2. #72
    Jul 2011
    Garner, NC
    865
    i just recieved a 670 for an anniversary gift from my wife. needless to say, it will be going into her MaxIV. Need some help with wiring,, what all do i have to do or get rid of to make it compatible to my MaxIV. It is currently wired to receice a Kohler Command that I put in last year but failed shorltly after but had a Briggs in it originally. Also, what belt is used for this conversion or can the original Briggs belt work? Thanks guys!!
    BIGFOOT ALUMNI
  3. #73
    Quote Originally Posted by fmints View Post
    Get ahold of Tommy or the Michiganers, they've both just done them.
  4. #74
    Jul 2011
    Garner, NC
    865
    Thanks alot Jim!!
    BIGFOOT ALUMNI
  5. #75
    Nov 2009
    Michigan
    730
    I really need to draw up a wiring diagram for that engine. I'll try and remember to do it later. As far as belts. We run the stock max iv belt for briggs.
  6. #76
    Jul 2011
    Garner, NC
    865
    Quote Originally Posted by Toys4Me View Post
    Thanks for the info on the belt! I’ll get one ordered today! A wiring diagram would be nice, if you can remember,,, I do know how it is to forget things at time!! Thanks a lot!!
    BIGFOOT ALUMNI
  7. #77
    Sep 2009
    Nebraska
    108
    i too am currently looking at re-powering my attex rig and am also strongly leaning toward the predator 22hp engine. My current rockwell jlo 399 is just not reliable enough and is quite difficult for locating parts for. I'm curious as to what clutch you ended up using that would with stand the torque and rpm's from this motor? as well as if you had to re-spring the t-20 driven clutch? if so, what spring did you end up using?
    Nathan
  8. #78
    Nov 2009
    Michigan
    730
    I strongly recommend the swap. The engines are good stock and aftermarket parts are also available. I run 780 clutches. On the light machines I run the green springs in the secondary and in the heavier ones the red.
  9. #79
    Sep 2009
    Nebraska
    108
    I see a lot of members on here using the comet 780's, yet they are only rated up to 18hp...these are capable of withstanding the 22hp that these engines are putting out?
  10. #80
    Nov 2009
    Michigan
    730
    My 670 predator is putting out close to 40hp and no issues.
