Originally Posted by
dirtdobber
I'm not sure what normal is for these engines, but 170 does seem high. If I'm applying the right logic, pressure and volume are proportional. With atmospheric pressure being 14.7 pounds, and assuming the pressure inside the cylinder on the intake stroke is 14.7, then then it has to compress 11.5 times to reach 170 psi. A good old stock Chevy small block engine would have somewhere around a 8.5:1 ratio, but I'm not sure what these engines should have. But, I can't think of anything that can go wrong and cause increased compression, unless maybe the exhaust valve is not opening and the cylinder is able to draw in a little more air than normal and thus is reading a higher compression (that's just a wild guess, by the way). Especially since the compression on one cyl. is nearly double the compression on the other. You did read your gauge right (psi) and not some other units??
Post some pics. Not sure if they will help but pics are always fun to look at.
