One way to bend tube if you have a torch is to fill thee tube with sand, cap the ends, then heat the bend area with a rosebud and bend manually. The sand prevents the tube from collapsing. Also, if you're going to use pipe, you also don't want to use galvanized pipe. The fumes from the zinc coating is pretty nasty stuff to breathe. If you do have to weld galvy, you must first grind off all of the zinc. You can apply spray on cold galvy to the area after you're done.
