Winching?
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: Winching?
  1. #11
    Join Date
    Jan 2013
    Location
    Sidney Ohio
    Posts
    509
    I thought about using a howse fairlead. But I'm torn. I see good and bad in both.
  2. #12
    Join Date
    Sep 2014
    Location
    Fort Mac
    Posts
    12
    A note about the cable end: it's the last few wraps on the drum that actually hold the cable on, not the end. The only reason there is an end fitting, brazed ball, or set screw is to keep it in place when it's not under tension. But under load, you always want to leave around 5 wraps on the drum at the minimum and the physics of that tension and friction on the drum is what anchors the cable to your winch under high pulling force.
  3. #13
    Join Date
    Jan 2013
    Location
    Sidney Ohio
    Posts
    509
    Good point. Thanks.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
