Brake cooling fan
+ Reply to Thread
Results 1 to 9 of 9
Thread: Brake cooling fan
  1. #1
    Brake cooling fan
    Hi. Started up my 2000 Conquest today and the brake cooling fan didn?t come on. Any ideas what the problem could be would be much appreciated. Can the machine be used without the fan. Thanks
  2. #2
    Join Date
    Mar 2010
    Location
    innisfil,ontario
    Posts
    1,420
    check see if you have power to the fan.maybe its just a blown fuse???????
  3. #3
    Join Date
    Mar 2021
    Location
    Atlantic Canada
    Posts
    44
    I second plott hound on that one, first thing to check is the fuse. My old machine still has the old school tubular fuses for the break fan and sometimes just a quick spin around or replacement is all it needs. I had a wire break off the back of my ignition switch once as well which also disabled my break fan.
  4. #4
    Quote Originally Posted by plott hound View Post
    Would that be an inline fuse. Don’t seem to be anything blown in the fuse cluster. Thanks for your reply
  5. #5
    Thanks much for your help.
  6. #6
    Join Date
    Mar 2010
    Location
    innisfil,ontario
    Posts
    1,420
    it should be in the fuse cluster. here is a picture. https://www.argoadventure.com/127-12...KI_p_7892.html
  7. #7
    Join Date
    Sep 2010
    Location
    rhode island
    Posts
    696
    also check the wire connections, something may have come loose. vibration or bouncing from rough rides can and will loosen connections.
  8. #8
    Thanks. Very much appreciated
  9. #9
    Thanks for your help.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
