Does anybody know the maximum load for towing is?
Printable View
Just done a quick google search and it states the towing capacity for a conquest is 1600lbs.
Argo Conquest 8x8
Here is some other towing capacities for other models...
Vehicles | Ottawa Argo
Max Towing capacity for my Conquests is as much as they can pull without spinning out. Usually limited by ground conditions, soft, muddy, Muskeg, ect.
Hahaha, I think that was 17 sheets of 1/2" and 3/4" OSB Plywood across the back of the machine, I think thats close to 1,200lbs. Then the gear under the wood, plus a couple 200+ lb guys. It was probably about a Ton on the Conquest, that was the second load that day, and the only time I've ever broke an Axle. Was winter and in deep snow, no trailers involved :-).
https://m.youtube.com/watch?v=B6XxApY0_4U
No, not at all. My machine ended up sitting right there in the middle if the trail for about 2 months, untill spring when I could get to it with my quad and change out the axle. I drove my buddies machine back out.
This is from the trip in to fix it
http://youtu.be/C8EkC7L3ky0
Very cool the trips you get to make. Around here you can't go very far before you come to a paved road. I appreciate you sharing all these super cool videos.
