Originally Posted by
Old Tucker
You are right about the track been easer on the unit. If you are running a narrow track and do not need axle extensions. Its only simple physics The farther you move the wheel out from the bearing, the more stress there is on the bearing and axle. And thats what comes into play in a big way on the stock conquest axles flanges.
Now we do not know your conditions, but I assume they are in rough conditions for you to want the Escorgo Track. I would say stick to the elevated belt track for sure. As for the turning ability of the elevated belt is far superior then a flat bottom track. Because the flat bottom will dig into the snow as you try to turn, and the elevated belt design will try to lift itself out of the snow or mud. The angle of attack is different. That alone, makes it a lot easer on the argo. When I went from a flat track to the elevated belt, It was like power steering. What a big difference it made.
There is, I think, Three design out there. and all are good. One may be a little better then the other for your ridding conditions.
I also took my time with cold beverage. and feet up. Then jumped up, ran out side to look at the argo. I think we all do. Its a must when you have these toys.
