I was wondering if you might know what size trailer that I would need to put a Argo 8x8 Frontier 650 with tracks. I know the sides are right at 60 inches but are the tracks wider then the sides.
Hi mike, welcome to the forum. For your technical question try starting a thread in the Argo forum as this thread primarily serves as an introduction thread and not everyone checks it.
Hello first time on this site, has been very helpful. Am also new owner of 1990 ( I think) max iv . Have already run into some sprocket problems. Can somebody tell me if running in deep water do you keep bilge pump on? And about how much is a chain and sprocket will cost? Thanks
Hi grimygrammy, welcome to the forum. A machine that has been maintained properly should not leak any water. If you are leaking a little water, greasing your bearings may help but if it is enough water to require a bilge pump, most likely you need to replace your bearings. As for cost on chain/sprocket, chain is dependent on the quality that you get. Search the site for recommendation on which manufacturers to avoid but most agree that the USA version of Diamond brand chain is a very good chain (there is an inferior Chinese Diamond chain version that doesn't last as long). The sprocket will depend on which one you have damaged. You may be able to post a wanted ad in the classified section of the site and post a picture of the sprocket tube you need along with the number of teeth on each of the sprocket. Otherwise you should call a Max dealer or Recreatives Industries directly: Amphibious Six-Wheel Drive All-Terrain Vehicles: MaxATVs - Call 1-800-255-2511 to get an idea on the price of a new one.
Hi Positrac, welcome to the forum. From the looks of how loaded you have your Bigfoot, you could use a little more room that an 8x8 would provide as well.
Nice to see another Albertan rider welcome
Hey grimygrammy,
Like Mike said, if you need to keep your bilge pump on, you have a problem.
I put a 500gph pump in my 1997 MaxIV and it has never turned on, I do test it occasionally, just to be sure.
What is the issue with the sprockets, I have some axles and sprockets I don't need anymore, check the ForSale section for details.
Chain is very important, do a search for "chain" or "530 chain" and you will have enough to read to last you the winter.
The trouble with retirement is.... I never get a day off !!!!
Hey There.. Just picked up a 1971 Bazooo.. very original and conplete.. needs a bit of work.. and there is not a lot of info out there.. but I see there are others with a Bazooo.. so I'll be here looking for some help.. And when I start work on it I will document the progress on my web page link in signature.
See what's up in my workshop.. www.robeye.net
Hi Robeye, welcome to the forum.
