Swamp Stomping that's what we ride in in Florida
Nice videos.
Nice example of why not to use non chevron type tires, either open bars or closed.
The Argo in the Video has 22" Kenda bear Claws, They don't swim very well but do move the machine forward and backwards in vegitation free water all beit slowly, those tires work quite well in thicker mud and that machine sticks to side hills like glue but struggles when it's bobbing for traction.
My max has the 26x14 Vendetta tires, they skid very easily and seem to work "OK" in most mud I've been in. They swim forward VERY fast and lift the machine up in the water when I blip the throttle but they do absolutly nothing in reverse lol. I spent 10 minutes between 2 trees on a shoreline I couldn't climb up on because it just doesn't move in reverse. The tire design prevents the usual "mount the front two backwards" solution to this problem.
Try reversing your rear tire on the very back of each side, that should give you some reverse swimming capability without taking much away from your forward speed.
Canadian Zuk, Can you explain why the tire design prevents the usual "mount the front two backwards " solution to this problem??? Thanks
You know, I could be completely off base with that comment. I just looked at the tires again and for some reason I had it in my head the trailing edge of the lugs had more of a smooth transition into the tire carcass. I'm going to turn the rear two tires around and try it out then give an informed opinion vs my previous assumption.
If that Argo had the new 22" Argo swimming tire I think you would find it would have a lot more Versatility! Pertaining to the Vendetta's on your Max, I absolutely love those tires. I had the 16" wide version on my Max for awhile and found them to be the closest tire I could get to tracks. As I understand it the 14" version swims very fast in the water. My experience with those tires was to keep them spinning and they would walk through just about anything as long as you kept them spinning! The ride on the Vendetta's was better then anything else I have experienced.
I would love to have a set of the 14" inch wide Vendetta's on my Argo 8x8. I think they would be they best compromise between tracks and tires and just might set the record for swim speed on an Argo 8x8.
Beautiful video.
