Best way to clean out old nasty Gas Tank
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 20
Thread: Best way to clean out old nasty Gas Tank
  1. #1
    Join Date
    Nov 2010
    Location
    Charlotte NC
    Posts
    146
    Anyone have any good results from a way to clean out old gas tanks.
    I have a metal tank on the surtrek and a plastic tank on the attex.
    Also when I put a magnet in the surtrek tank there was a TON of like metalic mud like sludge. It would stick to the magnet and come off that with my fingers like mud. What could this be? (I went in with the magenet 25+ times and everytime came out full.)
    Also does anyone recommend any sort of tank sealer/ coating once I get the tank clean.
  2. #2
    Join Date
    May 2008
    Location
    Alto MI
    Posts
    611
    i would slosh some fresh gas around in it.
    Kevin Hough
    TREBMASTER
    (____>
    .OOO
  3. #3
    Join Date
    Nov 2010
    Location
    Charlotte NC
    Posts
    146
    Why gas?
    I have tried Purple power degreaser.
  4. #4
    Join Date
    Apr 2011
    Location
    Ohio
    Posts
    149
    Whats wrong with a garden hose clean it out let it dry for a coupel of days and add fresh gas. Thats all we every do with older cars.
  5. #5
    Join Date
    Nov 2010
    Location
    Charlotte NC
    Posts
    146
    Quote Originally Posted by wildbill335 View Post
    There is still a bunch of Crud in the tank. (^^^^ ALL the METALIC mystery stuff.) Which I really do not want in my origional engine.
    Found this stuff called Red-Kote. Seems to be the best truff on the market, easy, and priced reasonably.
  6. #6
    Join Date
    Jul 2011
    Location
    Western New York
    Posts
    267
    I would do a search of electrolysis rust removal. I know a guy that uses it to clean out metal motorcycle gas tanks and says its the trick.
    here is a short article on it.
    Electrolysis for Rust Removal | eHow.com
  7. #7
    Join Date
    Feb 2011
    Location
    michigan
    Posts
    352
    I use a pressure washer then blow it out with compressed air.some old times told me they would put about 20 bolts or nuts in fill the tank halfway with hot water then put the lid on and shake like crazy-I prefer the pressure washer aproach.
  8. #8
    Join Date
    May 2007
    Location
    Kings Mountain, NC
    Posts
    7,788
    If you will search the site there are a couple of threads on this same topic that will help you. Here are two to get you started:
    http://www.6x6world.com/forums/gener...-cleaning.html
    http://www.6x6world.com/forums/gener...-gas-tank.html
  9. #9
    Join Date
    May 2009
    Location
    Meadville, Pa
    Posts
    3,286
    I like acetone and bolts. I've used it on several tanks with no problems and it dry's faster than water.
  10. #10
    Join Date
    Jul 2011
    Location
    Kittanning, PA
    Posts
    751
    Electroylisis works good, and my own little thing i like to do is Muratic acid, along with nuts and bolts inside, shake it up till the cows come home, then dump it out and look in at the shiny new surface. I WILL FOREWARN YOU...if the tank is thin, it may make it leak, but i've only had this happen one time.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
