Hello, New member here, just bought a AC Terra Tiger minus engine. What would you recommend for good power? 2 stroke or 4? Thanks in advance for any suggestions.
Jim
Hi Jim, welcome to the forum. For starters, check out this thread: http://www.6x6world.com/forums/other...iger-help.html You may want to start a thread in the Other AATV forum since there are only a handful of people that check the introduction thread on a regular basis. Someone should be able to talk through some options with you there. Again, welcome to the forum and good luck with your Terra Tiger!
Hello from Alaska. I bought a MAX IV with a serial number 5710. Which if we have looked correctly it was built in 1978???? Let the wife drive it this past weekend she loves it so now I will need to figure out how to keep it going. Was told that it has the Koehler 25 hp motor but have not been able to find the data plate or serial number on the motor yet
Hello, I have been reading posts on this website for a while now and thought I should join.
I purchased a 8 X 8 Argo powered vehicle last year.
It is called a Beachlauncher, and uses Argo drivetrain components.
It is used to launch and retrieve boats from the shore.
It has worked very well so far; however, it does require maintenance, and by joining this website, I hope to be able to gain some knowledge of the Argo's common problems and solutions to those problems.
Hello Matt, welcome to the forum. Thanks for sharing the photos of your Beachlauncher. I haven't seen one of those before either but it is a neat idea.
