Hustler 880 Plow
+ Reply to Thread
Results 1 to 7 of 7
Thread: Hustler 880 Plow
  1. #1
    Question Hustler 880 Plow
    I have recently bought a hustler 880 with a 400ccw motor in it. With winter coming up I'm trying to figure out how to make a plow for it. Anybody have any ideas?
  2. #2
    Join Date
    Jun 2007
    Location
    Buffalo, NY
    Posts
    6,442
    I'd suggest doing what Recreatives does on their Max ATVs and make two steel plates that bolt onto your front and middle bearing flanges. Fab up a pair of plates for each side and weld on a pin on each for the plow frame to mount and raise and lower on. Then use a winch to bring the plow assembly up and down.
  3. #3
    I'll throw my 2 cents in. The 880 can have some frame issues as its not as robust as the later hustle models. The other issue is the 2 stroke engine. high revving - low torque isn't all that great for what you are trying to accomplish. i'd just have fun with the machine and not dump a tone of $ at a plow set up that will leave you wanting.
  4. #4
    Thanks for the responses. I will look into jpswift1's idea, or maybe I will just use it for fun this winter
  5. #5
    Join Date
    Jun 2007
    Location
    Buffalo, NY
    Posts
    6,442
    Use it for winter fun, and then while you're doing that, keep your eye out for a good deal on a 4 stroke machine to use as a workhorse. You can never have too many 6 wheelers!
  6. #6
    Most snowmobile engine make way more hp than any vanguard 20hp... tons of ATVs come with two stroke engines they will have plenty of power to push a plow..a 440cc make 80hp and more torque than a Vanguard
  7. #7
    Join Date
    May 2008
    Location
    Winchester,Illinois
    Posts
    450
    I dont think the old 440's were rated that high,seems to me they were 38-40 hp range...
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
