All,
After a complete restore of 950 with a 16hp cast Kohler I will now embark on the next adventure with my 950 that incorporates an aluminum chassis and springer design (tangent from my previous springer post) - working on the component kit now. Since this is going to be for Colorado elk and deer hunting I anticipate water crossings only with no swimming.
The 6x6 design is now ready and cut sheets are being completed for the aluminum sheet metal and chassis. The build will begin this winter. Will have to reacquaint myself with aluminum welding. I have found a shop in Boulder that will laser cut all the sheet metal components including brackets, body plates, suspension arms.
The plans are to refresh the T-20 and couple it to a 40HP FI Subaru-Robin engine to run at a low duty cycle, accommodate the extra weight, and drive a hydraulic pump for implements. The sprockets and chains will be upgraded to a double configuration. I am also designing a closed oil system for the drive mechanisms similar to that on a skid-steer which will take some more thought.
Additional notes:
1. Drive train is from my 950 Hustler
2. External axle center lines have been been offset to accommodate 27" wheels.
3. Uses inexpensive motorcycle shocks
4. No change to drive assembly needed (sets on top of frame as is).
5. Tool box on each side of bed. Rack to be added (not shown)
6. Controls to be modified for easier access.
7. Kept compact design for woods navigation.
Questions,
1. I am looking for about 30-35mph with tractor like grunt as I will be pulling a hunting / camp trailer into the back country in Gunnison. With a 40hp gas engine what would the appropriate gearing look like?
2. Any concerns on the T-20 holding up under that type of load? I assume not since it was designed for steers.
Any input appreciated.
Thank you.
