Can anyone tell me what the differences are in a hustler 900HK and a 950? Frame and tub?
Thanks
Thanks
Steven Untiet
I have pored over everything hustler on this sight, I am specifically wondering about the frame and tub differences. I was trying to find a way to ship one up to Alaska but can't do it for less than $1200 and i don't know if it is worth it. My tub is pretty fair, I've welded up all the holes (for the most part). I swam the machine for over half hour and didn't get enough water to run the bilge! And my frame is as straight as i could get it and I've welded up some added support. BUT i do have sag in the tuba and top and from the few pictures i could find the 950 frame seams to have added tub supports. What do you you guys think? Is $1200 worth the upgrade to the newer model frame and tub? And as a bonus i have an extra t-20 and was thinking of using the other frame for a tracked rig for winter use? Although you see Max's up here for $2000 and up sometimes?
Steven Untiet
No idea on the tubs, though while trying to figure out what I had found this.
Seat support different, battery is under seat with full width plate, (900)crappy chain tensioners especially at trans. which you addressed quite well, maybe slightly thicker side rails ( big maybe). If you can squeeze 25's under your lower tub then nothing I can see.
Believe raceone3 may have better info as he had 900(parts atleast) 950 and 980.
