Here's what I have. I can fab a mounting system for it but i assume the original config has a greater fuel capacity.
Let's not hijack this thread any further.....
That is a Max tank, if you want to trade for a stock tank I'd be willing, I'll get some pics up. The picture of Joe's tank is specific to the fiberglass Hustlers.
Thanks Jim. I sent you a PM.
I finished the engine mount today. I made it out of 1" angle iron and made the holes slotted for side to side and front to back adjustment.
IMG_20160409_193708125_HDR.jpgIMG_20160410_174723374.jpgIMG_20160410_181623149_HDR.jpg
Borrowing tools is for the weak.
2000 Max IV, 25hp Kohler Command, 26" Titan Tru Power AT's
1996 Max IV, 18hp Briggs, 24" Serwas
1998 Max IV (project in waiting)
1995/1999 Max II, 16hp Briggs, 21" Rawhides
Hustler 950 (Project in waiting)
I am looking for replacement nylon rollers. I plan to eventually make better ones, but I just want to replace a couple of the old ones. Will the ones in the link work? Are they the right type of nylon?
McMaster-Carr
x... also check out "" black ace chain tensioners" co., they sell idlers for chain. johnboy va.
I removed the on engine fuel tank last night and checked out the chain tensioners. The tensioners are rough, so I ordered some urethane rollers with built-in bearings that Don used on the BFD Hustler.
I plan on installing a low pressure 2-3.5 psi electric fuel pump because I don't have the valve cover with the vacuum port.
Also, I just got the throttle swivel in the mail. It fit the Briggs throttle perfectly. I used a Walbro 52-501.
I decided not to use an electric pump and I found a used Valve cover with the vacuum port. This will make the fuel system much simpler.
Took the top off of it today and repaired the steering sticks. They had rot at the bottom, so I added some angle iron to reinforce them.
I found the Hustler model tag, but the model number was faded away.
