wisconsin 35 hp w4-1770
+ Reply to Thread
Results 1 to 3 of 3
Thread: wisconsin 35 hp w4-1770
  1. #1
    Has there been anyone try putting in an Wisconsin 4 cyc. 35 Hp in a Hustler? I found one for sale but if it might fit.
  2. #2
    Join Date
    Jan 2015
    Location
    Dallas, Texas
    Posts
    178
    I haven't tried anything that big in a machine. I do have a buddy with a 35 horse Wisconsin on the back of a water truck. From what I remember of it, they have a wider foot than the stock hustler motors, so you'll probably need to fab a motor mount. They are also tall, so something will need to be done with the back seat. Exhaust most likely will need to be modified. Depending on the exact dimensions of the motor, a longer drive belt may need to be used. Also, you may need to step up the clutch, assuming you have a 40 series. Other than possible rewiring, I cant think of anything else that might have to be altered to fit the motor.
    Meep Meep
  3. #3
    Join Date
    Jun 2007
    Location
    Central NJ
    Posts
    1,470
    also a big weight penalty. Your best bet is to keep the Hustler light as the hull displacement is pretty significant so your swimming will be compromised with weight. You are better off with a 25 hp clone single or small briggs v twin.
    Acta non verba
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
