What's the drain plug/hole supposed to look like?
+ Reply to Thread
Results 1 to 4 of 4
Thread: What's the drain plug/hole supposed to look like?
  1. #1
    Join Date
    Feb 2016
    Location
    Mississippi
    Posts
    1,108
    Hey guys,
    My 950 has a semi-rough cut hole, in the back wall of the tub, that is about 1 in or so in diameter, with the bottom of the hole right against the bottom of the tub. Is this the original way hustler provided for the drain? What type of plug did it use?
    If someone has any pics of what it is supposed to be I would appreciate a post.
    Thanks in advance.
  2. #2
    Join Date
    Oct 2007
    Location
    statesville, north carolina
    Posts
    2,604
    Yep, that sounds about right. I use this from the inside out. Sea Dog Snap Handle Drain Plug, No Safety Chain, Brass, Bulk - Walmart.com
  3. #3
    Join Date
    Feb 2016
    Location
    Mississippi
    Posts
    1,108
    Frame 2.jpgI take it you an access your from the inside out. I think when I get mine all back together, the drain hole will actually be under that rear portion of the frame cross member (circled in red).
    I hate to put it in from the outside because it will catch all kinds of junk and likely get snatched out. Maybe I can us an expansion plug or something similar that will be pretty flat on the outside
  4. #4
    Join Date
    Oct 2007
    Location
    Posts
    2,604
    it will be directly under that. its a pita, but you can get there
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
