new guy with 2 hustlers to make 1
+ Reply to Thread
Results 1 to 5 of 5
Thread: new guy with 2 hustlers to make 1
  1. #1
    just saying hi, first post and all...
    ive visited here a few times and have had a hustler sitting in the corner of the shop for a few years with no motor and questionable trans, recently picked up a second one with a busted up tub but supposedly running so planning on taking two to make one good one. keep your fingers crossed for me!
    when i was a kid my uncle had an alice chalmers artic cat ( i think ? ), he lived in a river valley in the Pennsylvania mountains and it was a blast to drive through the much and the river around there. now, hoping to give the kids the same experience with a hustler.
    they look to be the same models to me? if anybody can tell me what model they are or any other info would be much appreciated
  2. #2
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    The one in the back (2 stroke with 3 holes in upper body) is a 900, the front one with 2 holes looks newer maybe a 945HK?
    If there is a plate on right upper near the key switch that would be it, if not the tag probably went with the original engine.
  3. #3
    thanks! theres no tag near the key switch. other than the different holes and possibly different original engines are they pretty much the same?
  4. #4
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    Yes, minor differences such as possibly;
    different seat frame/battery position, sprocket tooth count, chain adjusters, wiring, exhaust exit, etc..
  5. #5
    hi again,
    im starting to tear these down and wanted to see if theres a source for parts? mainly chain rollers and carb rebuild kit?
    looks like the factory fuel pump ( mounted on the carb) had issues as it was bypassed and a remote fuel pump was used instead. the remote fuel pump is still the same style that works off of crank case pressure though
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
