A New Hustler Owner
+ Reply to Thread
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 30 of 30
Thread: A New Hustler Owner
  1. #21
    Join Date
    Feb 2016
    Location
    Mississippi
    Posts
    1,108
    QT,
    Here are some pics of my transmission linkage along with enough dimensions to rebuild your. The good news is you can just add on where the old parts were cut off.
    Shift dimensions.pdf
    I also sketched for you what the factory split shift arrangement looks like. It's simple enough and I think you will get the idea. You need two shifters, though.
    Split Shift.pdf
    I have a couple more pics I'll have to add in a new thread.
  2. #22
    Join Date
    Feb 2016
    Location
    Mississippi
    Posts
    1,108
    more pics of my shift linkage
    One of these pics is what my shifter looks like.
    Another modification you should consider while you are building is beefing up the mounts for the transmission. Currently, your transmission is held in place with 4 bolts and slotted holes. In a high torque situation, the trans can twist out of its mount. If you will notice in my pics, I have a piece angle iron that runs from the shift linkage supports (1/4 x 2 flat iron) and captures the top two bolts. It also holds the diamond shifters in place.
    Two other things I see missing are the seat support, which crosses above and just forward of the transmission (its in my pics) and the bracket that connects the rear hitch to the frame. You want this bracket so that you have a solid connection point and not pull the hitch out of the plastic. It slipped over the engine mount bolt.
  3. #23
    Does anyone have a drawing or some pictures of the shift levers that they would share? Dirtdobber mentioned a split shifter. Anyone have plans for that?
    Thanks!
  4. #24
    Join Date
    Feb 2016
    Location
    Mississippi
    Posts
    1,108
    The sketch I gave you in post #21 shows you how to arrange the linkage at the transmission. At the drivers compartment, you just need a second gear shifter and linkage.
    Some have mounted shifters side by side, and some have mounted them on either side of the machine. The best you can do is take the concept and design something that works for your machine. I doubt anyone is going to be able to give you precise instructions...but I could be wrong.
    I have a parts machine that is set up with the factors split shift, but I can't get to it right now to take pics. Maybe over the weekend I can.
  5. #25
    I have a chance to get a Kohler 25hp. It has a 1 1/8 inch shaft. Is that an issue?
  6. #26
    Join Date
    Feb 2016
    Location
    Mississippi
    Posts
    1,108
    I'm not sure. If you currently have a driven clutch it will be a 1 in bore, so you may be able to have it machined to 1 1/8. If you have to buy a new driven clutch, check for compatibility with your existing driven clutch. Someone with more clutch knowledge than I will hopefully chime in. But, if you can put 25 horses in it that would be great!
  7. #27
    I only have a driven, no driver. I'd have to find a 1 1/8" bore driver without breaking the bank.
  8. #28
    Looks like a no-go on the 25hp Kohler. I did end up purchasing an 18hp Vanguard engine that should serve me well. I will probably start a build post when I get things rolling in a few weeks. I am going to need help....
  9. #29
    Join Date
    Feb 2016
    Location
    Mississippi
    Posts
    1,108
    Qt here are some pics of a factory split shift.
  10. #30
    Thank you dirtdobber! Anything helps.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
