Blow in the tank with the forward end of fuel line in a bottle until fuel appears.
Be sure the filter is pointed in correct direction.
filter is correct i read the tab on the fuel pump has to be bent a little??
removed the pump never seen anything wrong. i seen video where they bent this tab back a but more and it started pumping since the tab wasn't riding on the cam properly in order to pump. is the tab on mine bent back to the point where its not on the cam?
anybody this got me stumped its a 2 year old 130$ pump could there be dirt in the inlets?
Did you blow fuel up to yet? I have an idea whats wrong, but if you dont find it i could be wrong.
i blew in the tank i tried sucking fuel up to see if fuel line or something is clogged but i couldn't seem to get it to work without getting poisoned from the fumes inhaled lol. when i blew in the line tot eh tank u could hear bubble being made so nothing is blocked so i think? whats your theory Jim?
Wasn't it you who had the primer ball?
My guess is playin with the fuel line you may have cracked the pick up tube letting the pump suck air.
Other guess you are missing the cam with the pump, the only good way to install the pump is with the cam up, fuel pump should be hard th get in needing to push it down to get the bolts in.
i did not have the prime ball. but i tell u changed the pickup tube though
Are you able to draw fuel up the line at all?
Perhaps using a fluid extractor of some kind?
If not you have a hole or a restriction of some kind.
See my photos here.
https://www.flickr.com/photos/giarc_dranrab/albums
Videos:
https://www.youtube.com/channel/UC8m..._as=subscriber
i will try
