Max 8x8
+ Reply to Thread
Page 3 of 11 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 106
Thread: Max 8x8
  1. #21
    Join Date
    Jun 2007
    Location
    Central NJ
    Posts
    1,470
    Mike if you are looking for a nice 4cyl 4 stroke at a reasonable price, even comes with a wrecked snowmobile attached to it.
    YAMAHA RX1 IN NEED OF TLC: eBay Motors (item 120647838148 end time Nov-22-10 05:33:23 PST)
    Then again you probably don't need 150 hp. It would make one heck of a racer.
  2. #22
    Join Date
    Jul 2007
    Location
    North Huntingdon, Pennsylvania
    Posts
    429
    I bet you could find a Geo metro with a 3cyl pretty cheap.
  3. #23
    Join Date
    Oct 2007
    Location
    statesville, north carolina
    Posts
    2,604
  4. #24
    Join Date
    May 2010
    Location
    Kerhonkson, NY
    Posts
    179
    Quote Originally Posted by jerseybigfoot View Post
    If your interested I can look at this for you, it's only 10 miles away.
  5. #25
    Join Date
    Jan 2008
    Location
    Vicksburg, Michigan
    Posts
    3,507
    Wow Mike, Im excited!! Definitely keeping my eye on this thread.
    If you are interested in a 3 cylinder geo metro engine. I have one that has been sitting for years. It ran when parked kinda thing. Not sure what it needs but I can double check that the engine will turn and is not frozen. If you want it and can can travel my way to get it you can have it free. As long as you take lots of pictures!
  6. #26
    Join Date
    Jun 2007
    Location
    Buffalo, NY area
    Posts
    2,968
    That would be very very cool Larry! Thanks very much for the offer! That's very generous of you. I don't know for sure what direction I'm headed in with the engine. A Metro would be about perfect, but if I can wrap my hands around a small turbo diesel, I may do that. It's a bit far off to make up my mind for certain.
    I dropped the body off at a plastic welder nearby today. He won't even be able to get to it until Monday of next week, but agreed that it's a little challenging. He likes the project, and one of his employees just kept smiling at the idea of it.
    I got a nice frame from RI, updated with larger bearings, reinforced T-20mount, etc., and I'll have to lengthen it and figure out how to run chain to the back axle. Metal will be the fun part, I'm already sick of welding plastic, and the project is less than a week old.
    ~m
  7. #27
    Join Date
    Jun 2009
    Location
    Montreal, Canada
    Posts
    471
    Quote Originally Posted by hydromike View Post
    your friendly scrap yard may have a reefer unit off a trailer; most of them have japanese 3 cylinders diesel engines inside the shiny cover.
    2008 MAX-IV 500T 30hp Bandolero
  8. #28
    Join Date
    Jun 2007
    Location
    Buffalo, NY
    Posts
    6,442
    Mike, this project is soooooooo cool! I can't wait to see it in person........do you think you might have the tub done after next week? If you do, and you have some free time I'd love to come by and check it out. I know it's a little ways away, but what will you be using for tires on this beast? Can you imagine getting a hold of 8 Super Swamper Vampire ASXs?! That would definitely qualify for the ultimate 8x8 ever!!!
  9. #29
    Join Date
    Jun 2007
    Location
    Tulsa, OK
    Posts
    1,725
    I'm not familiar with the IV's drivetrain/chain system, but am thinking about how little length it takes to create a lot of slack, or too tight chains due to axle spacing. I know on my argo which has no real chain adjustment, .050" difference in axle centers would cause a big problem with chain slack. My point is, you might want to get the frame done first to make sure the chain slack is where you want, then bolt the tubs on and join them. Or maybe make a template off the frame and then use it on the tubs while joining them.
  10. #30
    Join Date
    Jun 2007
    Location
    Buffalo, NY area
    Posts
    2,968
    If I could AFFORD eight Vampires, that would be a plausible option.... This build is going to force me to sell some stuff to fund it. I HOPE that the tub is done by mid next week. I pick the frame up this afternoon, and begin thinking about how I want to lengthen it...
    Roger, I thought about the best way to go about axle spacing, and I basically came up with adding another 28"(ish), which is the axle spacing on the two back axles. This should let me keep the stock number of links on the "new" back end, and just fabricate a chain adjuster to go under the rear chain in some way (yet to be determined..... THIS Thomas Edison doesn't have his complete pile of junk, yet )
    ~m
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
