MaxII Bigfoot/Tall tub
+ Reply to Thread
Page 11 of 11 FirstFirst ... 9 10 11
Results 101 to 106 of 106
Thread: MaxII Bigfoot/Tall tub
  1. #101
    Join Date
    Nov 2009
    Location
    Charlotte, Mi/ Houghton Lake Mi
    Posts
    2,910
    I finally got around to making the full roll cage. I had a hard time picking a design that I thought looked good and fit the body. Uploaded several pictures to my gallery.[IMG][/IMG]
    Also added some more weight back to the primary clutch blocks, now I'm all ready to test it out at Haspin this weekend.
  2. #102
    Join Date
    May 2007
    Location
    Kings Mountain, NC
    Posts
    7,788
    Hopefully you don't test the cage this weekend.
    It looks really good Jim. I like the way all of the bars are angled in. They look good like that but that will also keep the cage from snagging on trees as easily as a cage that is more vertical. On the bars that go into the body in the original roll bar holes, did you tie the cage back into the seatbelt mount? Do you even have the stock seatbelt mount?
  3. #103
    Join Date
    Nov 2009
    Location
    Posts
    2,910
    Thanks Mike. I had a single roll bar on it, going through the body to the frame at the stock location. I tied this one to the frame reusing everything below the body. My seatbelt is actually bolted to the seat.[IMG][/IMG]
    I bent up bars using 90 degree angles, but scrapped it because I didn't like the way it looked.
  4. #104
    Join Date
    Jan 2008
    Location
    Vicksburg, Michigan
    Posts
    3,507
    Looks good Jim!
  5. #105
    What size pipe was used for the band?
  6. #106
    Tommy it looks like 1 1/2.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
