max iv axle leak
+ Reply to Thread
Results 1 to 5 of 5
Thread: max iv axle leak
  1. #1
    ksp7 is offline Registered Rider ksp7 is on a distinguished road
    Join Date
    May 2013
    Posts
    10
    max iv axle leak
    new to this site...and 6x6's I just bought a 1997 max iv. been thru all chains and greased zerks in and out snugged up flange nuts but still have a leak in two middle axles.
    they will get new bearings but the back two drive axles leak just a little..can i take the flanges off those and just re seal the outside with silicone without removing the whole motor and axle and everything.....thanks for the help.
  2. #2
    amphibious drew's Avatar
    amphibious drew is offline Amature Expert amphibious drew is on a distinguished road
    Join Date
    May 2009
    Location
    Meadville, Pa
    Posts
    3,286
    You can remove the tires and loosen the flanges. Just pull off the old ri rubber seal and wrap some 3m strip caulk around the assembly under the flange but on the outsides of the bolt. Tighten it down using hand tools, NOT AN IMPACT GUN, and you should be water tight again.
  3. #3
    Join Date
    May 2013
    Posts
    10
    thanks amphibious drew...i was hoping for that answer....the mid axles were a bit wobbly when i put it up on jacks so i
    am gonna go ahead and change them out....all the others feel fine so a re seal is in order ...thanks again for the help. thanks to all the others who post here this site has helped me alot with my new to me machine.
  4. #4
    Mike's Avatar
    Mike is offline Administrator Mike will become famous soon enough
    Join Date
    May 2007
    Location
    Kings Mountain, NC
    Posts
    7,765
    There is a video and photo-intensive how-to article in our how-to section on replacing the bearings. The photos and videos are for a Max II but they will apply to your Max IV as well. Check out that article and watch the video. It will show you the 3M strip caulk and how to get a water-tight seal.
  5. #5
    Join Date
    May 2013
    Posts
    10
    thanks mike..i watched it a little bit ago while searching for some info on the site.....i appreciate your help.
    I have bought a lot of man toys in my time but this 6x6 has got to be the most fun atv i have had.....i have
    also sold and traded most all of my other toys in the past but this thing is staying with me for awhile or until i upgrade to another one.......these rigs are more fun than a barrel of monkeys.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
