I have a max 4 was used as a hunting rig (Alaska) the unit made it in 30 miles of mud swamps, rivers but did not have enough power in climbing out of deep mud holes. My belt was not burning and the transmission oil did not smell burnt. My question to all you max owners is my transmission bands worn or is this max not rated for hard running with load. We had 1/2 a moose and camping gear coming out. The Argo on tracks did not have problems but had a low range transmission.
I like the max because it's easy to work on and tough as nails. I also was using jwheelz would pull 4 jwheelz had to remove center two would bog down in swamps. My magnum 20 engine did not seem to loose power.
Any ideas would be appreciated.
Rollnj
