I just paid like 12.78 per bearing.
I do not know. I had bought inner bearings and flanges for my bushing to bearing conversion on my max II.
I just bought the two outer bearings ( HC 207 20 R3) made by KML each for $13.82 $CDN and the inner bearing (SA 206 20G) also by KML for $11.17 as well as two new flange housings for the outer two bearings again by KML for $4.62. Only reason I am changing is because it is apart anyway to change out an axle. I have had the other KML bearings in there for about 4 years now with no issues. I bought these from a very small local bearing distributor.
Just got home for Easter. Checked the ticket and the big bearing was $17.44 and the small was $12.15 with $5.80 shipping.
Does anyone know the inner bearing number for a Max II after they changed the axle with snap ring retention for the sprockets and turned down the end of the shaft to 1 1/16" . When it was 1 1/4 " the inner bearing number was SA-206-17 that one had a locking collar,the new bearing does not have the eccentric locking collar. Has anyone replaced the inner bearings in a Max II after they switched to the turned down end on the axles. The last number in it will be a 17 but it is a different bearing number than a Max IV. Any info appreciated.
