Try using shoulder bolts. They have a solid shaft and threads are on the end with just enough room to put on a locknut.
I did use shorter bolts, they were grade 5, so that explains that problem. Now I have to figure out the bigger problem. I had a chance to take a quick look at it tonight and all the chains seem to be in place and no binding anywhere there. I tried turning the secondary or driven clutch by hand and I can't get it to budge in reverse or forward. In neutral I can move it but it seems way tighter than it should be, it takes allot of force to move it.
