This is a good idea. I have the factory canvas top on my machine, but it sags and collects water when it rains. This would work really well as a sun top and would help hold up the canvas top when one needs more protection. A sheet of HDPE should be easy enough to scrounge up.
A good quality soft top should have tension tabs welded inside the roof. These are secured just in font of the rear hoop and wrap round the top of the hoop, down the back and underneath towards the front (a bit difficult to explain but simple). You then pull these tight to the front hoop with tensioning straps. As the straps / tabs are tensioned it tightens the soft top up.
Hmmm. I'll have to take another look and make sure everything is installed correctly.
My MAX IV has a custom built cab on it ,but the man that built it passed away last year but you still can get a idea .http://www.6x6world.com/gallery/data...m/CIMG5086.JPG
Max IV has a high out put heater,custom cab, windshield wiper,suspension seat,new hydraulic brakes ,cargo rack on the front ,,,and I'm loving every minute of this .
Every time I walk to my bush lot, I have to walk by the truck canopy I had on my 1999 F250. The rear window is broken and there is absolutely no market for used caps in this area. I am thinking of taking a 6 in. slice off the top and using this as the base for a roof on an 8 wheel argo. Whatever happens, I will have to bust it up for the dump. I might just do the right cuts and try it out dimensionally to see how it looks and fits.....another project..... another day
ArgoTop.jpg Photo by guyvapeur | Photobucket
Today I went out and cut up the truck canopy. I took the roof portion and after a delightful afternoon of cutting and welding, I now have a roof on the argo
Last edited by guyvapeur; 01-02-2015 at 08:18 PM. Reason: Better with hammer than computor
Howdy. I built a top for my Max 4 several years ago using the existing roll cage and fabricated 1" square tube Gull wing doors. Enclosed it with 1/8" plexiglass. I painted around the door closures to make it look better but still kinda looks like the pope mobile. It still works well but I wish I had used 1/4 Lexan instead.(get cracks in plexi) I posted pics on this site but not sure how to find them. Try going to my profile and click on previous posts. Hope it helps. Wayne.
